Fundamentals Configuration Guide
HomeSupportSwitchesH3C S5820X Switch SeriesConfigure & DeployConfiguration GuidesH3C S5820X[S5800] Series Ethernet Switches Configuration Guides-Release 1110-6W103Fundamentals Configuration Guide
Download Book
Title Size Downloads
Fundamentals Configuration Guide-book.pdf 2.16 MB
Click the link on the right to download the complete book.
Preface
The H3C S5800&S5820X documentation set includes 11 configuration guides, which describe the software features for the S5800&S5820X Series Ethernet Switches and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The Fundamentals Configuration Guide describes how to configure the command line interface (CLI), log in to the switch, perform file management, configuration file management, and device management for your switch, upgrade the software, and perform automatic configuration.
This preface includes:
l          Audience
l          Document Organization
l          Conventions
l          About the H3C S5800&S5820X Documentation Set
l          Obtaining Documentation
l          Documentation Feedback
Audience
This documentation set is intended for:
l          Network planners
l          Field technical support and servicing engineers
l          Network administrators working with the S5800 and S5820X series
The Fundamentals Configuration Guide comprises these parts:
CLI Configuration
Login Methods
CLI Login
Web Login
NMS Login
User Login Control
FTP Configuration
TFTP Configuration
File Management Configuration
Configuration File Management
Upgrading Software Configuration
Device Management Configuration
Automatic Configuration
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none.
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
The H3C S5800&S5820X documentation set also includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
Pluggable module description
PSR150-A [ PSR150-D ] Power Modules User Manual
Describes the appearances, features, specifications, installation, and removal of the pluggable 150W power modules available for the products.
PSR300-12A [ PSR300-12D1 ] Power Modules User Manual
Describes the appearances, features, specifications, installation, and removal of the pluggable 300W power modules available for the products.
PSR750-A [ PSR750-D ] Power Modules User Manual
Describes the appearances, features, specifications, installation, and removal of the pluggable 750W power modules available for the products.
RPS User Manual
Describes the appearances, features, and specifications of the RPS units available for the products.
LSW1FAN and LSW1BFAN Installation Manual
Describes the appearances, specifications, installation, and removal of the pluggable fan modules available for the products.
LSW148POEM Module User Manual
Describes the appearance, features, installation, and removal of the pluggable PoE module available for the products.
S5820X [ S5800 ] Series Ethernet Switches Interface Cards User Manual
Describes the models, hardware specifications, installation, and removal of the interface cards available for the products.
H3C OAP Cards User Manual
Describes the benefits, features, hardware specifications, installation, and removal of the OAP cards available for the products.
H3C Low End Series Ethernet Switches Pluggable Modules Manual
Describes the models, appearances, and specifications of the pluggable modules available for the products.
Power configuration
S5800-60C-PWR Ethernet Switch Hot Swappable Power Module Ordering Guide
Guides you through ordering the hot-swappable power modules available for the S5800-60C-PWR switches in different cases.
RPS Ordering Information for H3C Low-End Ethernet Switches
Provides the RPS and switch compatibility matrix and RPS cable specifications.
Hardware installation
l      S5800 Series Ethernet Switches Quick Start
l      S5820X Series Ethernet Switches Quick Start
l      S5800 Series Ethernet Switches CE DOC
l      S5820X Series Ethernet Switches CE DOC
Provides regulatory information and the safety instructions that must be followed during installation.
Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration.
l      S5800 Series Ethernet Switches Installation Manual
l      S5820X Series Ethernet Switches Installation Manual
Provides a complete guide to hardware installation and hardware specifications.
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide
Guides you through installing SFP/SFP+/XFP transceiver modules.
l      S5800-60C-PWR Switch Video Installation Guide
l      S5820X-28C Switch Video Installation Guide
Shows how to install the H3C S5800-60C-PWR and H3C S5820X-28C Ethernet switches.
Software configuration
Configuration guide
Describe software features and configuration procedures.
Command reference
Provide a quick reference to all available commands.
Operations and maintenance
H3C Series Ethernet Switches Login Password Recovery Manual
Tells how to find the lost password or recover the password when the login password is lost.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
We appreciate your comments.
